New map Viewer and Line Labels
3601
22
12-13-2021 07:10 AM
WardMitchell2
Hello All,
I see that there have been some recent updates to the new make viewer. One of those being the labels associated with line work. The amount of labels per line has been greatly reduced (thankfully). The issue now appears that the labels do not move when you zoom in and out. In my case I am referring to road names . Roads tend to be long and have the label "sit" in one spot doesn't help the user know where they are at when zooming around in a map. I have only noticed it so far in the AGOL webmaps I have not tried the new line work labeling in a webmap application yet. I'm I missing something?
RussRoberts
Esri Notable Contributor
We have made some updates to line labeling in the map viewer.
- We have a setting on the label style panel for lines to enable/disable label repeats
- When disabled right now the label is in a fixed centroid position on the line.
- When label repeat is enabled there is a setting to set the interval distance to control the number of repeats
- Setting the overrun on labeling will allow smaller features to display labels that are larger.
RussRoberts
DJB
Hi @RussRoberts,
I'm running into a problem with labeling polygons.  The labels appear perfectly in the centroid of the polygon.  Works great if you see the full extent of the polygon.  Where the problems begin is when you zoom in.  The label no longer moves with the map extent.  So now, if I'm not zoomed in to the centroid of the polygon, I do not see the label at all making it virtually pointless.
Is Esri looking to fix this in future releases?
Any information you may have to offer would be greatly appreciated.
Thank you
RussRoberts
Yup this is something on the 4.x JSAPI roadmap to support and will be seen across all apps using that version of the API which would be Map Viewer, Dashboards, Experience Builder and Instant Apps for example.
ZacharyStanley
Is there a timeline for the roadmap updates?
HaileyWright1
@RussRoberts any timeline for this update for polygon labels? My colleague and I are researching elaborate and time consuming work arounds, which we'd happily avoid if this enhancement is close. Thanks!
Stefan_Thorn
Occasional Contributor II
Hi @RussRoberts ,
Those are nice new updates but missing really basic possibilities which seems to be very obvious for us to support our work processes with online maps. Now workarounds must be used to achieve these.
Just a few in my opinion:
1. alignment  of labels (above, on, under ) line is not available anymore in new map viewer.
2. rotations of labels on line to get perpendicular labels --> a workaround:
  • Generate Transects Along Lines
  • join new feature class with line feature class and transfer necessary attribute information
  • publish transects line and apply simple labeling
    • overrun is helpful here because the transect lines can be short and labels will show when zoomed out.
  • update/changes in  line feature --> work around again
In ArcGIS Pro:
Basic in AGOL:
After workaround:
3. start point (start, middle, end) of a label. this can help if you want to use multiple label classes and apply different style. In my workaround this would give the opportunity to show the X and O and align start and end. But now the labels will overlap.
4. Use of arcade/html tags like color font and font style.
RussRoberts
1. Is planned for 2022
2. Is also planned to support horizontal or vertical label placement. This is not in the web map spec so it does not transfer from Pro to Web.
3. This one also planed in the later half of 2022
4. Is on our roadmap but not assigned a release just yet.
MdeBoer
Is this still the case or has it been postponed?
RussRoberts
It's been postponed and planned for 2023 release.
