The public CSV is here:
Dropbox - Public Landings.csv
The error says this:
The layer was not created because no locations could be found. Make sure your data has valid addresses or geographic coordinates (latitude/longitude).
Yet I know the geo coords are valid. Because I've uploaded this same CSV directly to a different map.
Can anyone say why this fails?
Don
Do you have the file in your public area of dropbox or your private area. When I click on an item in my private area I only get the same options as your screen shot above.
Don,
Thats strange as I have copied your file to my dropbox account and it works ok:
https://dl.dropboxusercontent.com/u/25829160/Public%20Landings.csv
Are you sure you are using the public link because I do not have www.dropbox.com at the being of the URL like your link
Regards
Anthony
Thanks for taking time to look into it.
I see that your URL and the sample that Esri offers both differ from my URL. How do I fetch a "dl.dropboxusercontent" URL?
Don
In dropbox right click on you item and select copy public link:
I see only this. Significant difference?
Ok. I'm sure that's it. Thanks.
