My Map Viewer AGOL save twice when click Save and Open ? Why ?
846
04-06-2022 07:57 AM
DEAF_PROBERT_68
Honored Contributor
Why does AGOL Map Viewer save twice even I  click save ? Should it be just once when you click save ?
Mine had save twice when I click  save. Is that the normal way to do that ?
I worked on AGOL Map Viewer and work on nested groups because I had so many layers that I wanted to group.  Every time I open it does not save group  It puts me in a lot of work to re-do again.
What's up with that ?
Tags (3)
RussRoberts
Esri Notable Contributor
Can you describe the Save twice workflow you mentioned?
Are you just using Map Viewer and not saving in Map Viewer Classic?
DEAF_PROBERT_68
Honored Contributor
Hard to explain but whenever I work in Map Viewer in AGOL, you click Save  , it should save once...but then in a few minutes later it would show you save again …. Kind of of strange...
RussRoberts
I think I know what you are mentioning. Is it the 2 notifications 1) showing the save taking place and 2) showing it has completed
DEAF_PROBERT_68
Honored Contributor
Yes.  Every time I worked on AGOL Map Viewer, and watched whenever I saved,  it showed two notifications
First,
Then second,
