My Map Viewer AGOL save twice when click Save and Open ? Why ?
409
04-06-2022 07:57 AM
PROBERT68
Why does AGOL Map Viewer save twice even I  click save ? Should it be just once when you click save ?
Mine had save twice when I click  save. Is that the normal way to do that ?
I worked on AGOL Map Viewer and work on nested groups because I had so many layers that I wanted to group.  Every time I open it does not save group  It puts me in a lot of work to re-do again.
What's up with that ?
Tags (3)
RussRoberts
Esri Notable Contributor
Can you describe the Save twice workflow you mentioned?
Are you just using Map Viewer and not saving in Map Viewer Classic?
PROBERT68
Hard to explain but whenever I work in Map Viewer in AGOL, you click Save  , it should save once...but then in a few minutes later it would show you save again …. Kind of of strange...
RussRoberts
I think I know what you are mentioning. Is it the 2 notifications 1) showing the save taking place and 2) showing it has completed
PROBERT68
Yes.  Every time I worked on AGOL Map Viewer, and watched whenever I saved,  it showed two notifications
First,
Then second,
