We are looking at switching the single sign-on identity provider that our organizational AGO account uses from our on-premise ADFS server to Azure ADFS and are wondering if that can be a seamless transition if the NAMEID is the same in both configurations. We're hoping that accounts will persist after we switch and we won't need to modify ownership and/or group membership.
Thanks for any information, site, or personal experience!
Configure Active Directory Federation Services—ArcGIS Online Help | Documentation
Azure Set-Up: Tutorial: Azure Active Directory integration with ArcGIS Online | Microsoft Docs
Unfortunately, you must create whole new accounts, transfer content and group membership, and delete old accounts. There is no way to convert existing accounts at this time. Keep in mind, you can maintain both the "old" way of logging in (AGOL named users) and the "new" way (SAML) at the same time, so make sure to train your users on logging in correctly if you choose not to disable Esri logins.
Actually this turned out not to be the case for us-I may not have been clear but we were already using SAML via an on-premise ADFS server so we were not switching from named users to SAML but switching SAML providers.We were able to seamlessly switch from our on-premise ADFS server to Azure without having to create new users or re-assign content/groups. I wasn't the one that worked on it but my understanding is the accounts are tied to email account (email account served as a primary key) and as long as the SAML was consistent, AGO was able t.We tested first on our Portal installation and determined the specifications of what needed to be done and then switching AGO took just a few minutes.
We are scheduled to do this on Saturday. I was told that we had to create new accounts by several people. I greatly appreciate you posting this. It will hopefully help me. Thank you!
Good luck!As I mentioned above, I didn't do the work myself, but since we were able to essentially replicate our ADFS configuration in Azure, it did work seamlessly. If I understood right, our email address basically was our key identifier. We did test on our portal installation first so whatever minor quirks existed were figured out before trying AGO.
Signed in members can post, follow updates, and more. New here? Register a free account.
