Metadata on ArcGis Online
5183
02-03-2015 03:31 AM
CharlesETIENNE
Hi.
I'ld like to know if there's a solution to see the metadata directly on the ArcGis Online Applications.
When I'm on my application I have access to the informations of my layer by clicking onto an item (all attributes with their values).
In the same window, I'ld like to create a link to the metadata of this layer.
To get my layer in ArcGis Online, I publish my map as a service in Desktop but I'm not sure it publishes the metadata at the same time.
Thanks for you help.
Charles
TimWitt2
Charles,
at the moment this is not possible. The only way you could see meta data is if you would write it directly into the popup box.
Tim
TimWitt2
Charles,
Tim
ThomasColson
The recent update to AGOL includes a metadata tool, use of which results in a url to a metadata document.
