Measurement Pop up window overlap
1728
5
12-14-2012 09:56 AM
TanyaOwens
When using the basic web app area measurement tool inside a polygon on the map the map brings up the pop-up for that feature while you are trying to draw the polygon. Is there a fix for this?
MikeMinami
Esri Notable Contributor
I'm not seeing this behavior with the basic App. We recently made some updates to the website, so try clearing your browser cache agressively and see if that helps.
Mike
TanyaOwens
I have cleared my cache. What is weird about it is that if you run through it one time it works okay but the second time it brings up the pop-up window. I am curious, please follow these steps and see if it still works okay for you:
1. Identify feature then close popup window
2. Use the measure area tool (at this stage everything works fine)
3. Close measure tool
4. Identify feature then close popup window
5. Use measure area tool
At this point for me the popup window activates when I click inside the polygon to measure the area.
JaniceBaird
I get the same problem when using a mapid in the Basic Viewer.
Janice.
TanyaOwens
Mike? Anyone at ESRI - did you try the steps I wrote above and if so what was your conclusion?
MikeMinami
Yes, I can reproduce the problem. We'll need to take a look and see what exactly is going on.
Thanks!
Mike
