map viewer: enable editing in popup for tables
2239
10
06-04-2024 10:58 AM
mikaël
In map viewer, I have a feature layer added that comes from a Survey123 form, which contains 1 table related to 1 point layer related to 1 table related to 1 table.
Users can click on the point layer to access the related tables through a popup.
The popup has an "Edit" option which they can click to change values stored in the point layer.
I also have this parameter enabled in the point layer properties.
In the popup, when I click on related records from other tables, I do not see this "edit" button.
Plus the "enable editing" option is not present in the properties.
The feature layer containing all these tables and layer has editing enabled.
So, any way to easily edit related tables to a layer records in map viewer?
Thanks!
Laura
by MVP Regular Contributor
Oh I see. I experienced that the first time I clicked back and every time after it worked fine.
