Map Viewer Editing issues with "Recommended" and "Other" list in the pull down
465
05-07-2025 08:22 AM
JessicaSchneider
My map in Map Viewer has an edit feature that uses pull down based off domains.  When you go to select from the list, a pulldown appears that says "Recommended" then lists the domain options and says "Other" and there are no options.  Is there away to just show the regular options and not see the "Recommended" and "Other".
This map goes on to be used in experience builder and in that application the pull down gets annoying with a little stutter in between that you have to select from the Recommended pull down 2 times to get the value to stick.  My users asked for some quick pull down to quickly populate a point and they end up having to go back and make corrections because the option they thought they grabbed didn't actually populate.
I am afraid the option to turn this off is staring my in the face but I am stuck.
EmilyGeo
Hi @JessicaSchneider
does the layer contain subtypes? Typically that is what triggers the domain options to display with a list of recommended values. When you set up a subtype layer in ArcGIS Pro, you first create the subtypes and then you can define domains for specific fields within each subtype. This allows you to manage attribute data more effectively by restricting values.
However, the value in the drop down should persist after selecting it one time. If that is a recurring problem, I recommend reaching out to support to log a ticket with them so they can troubleshoot the issue and help to identify any bugs.
JessicaSchneider
@EmilyGeo No Subtypes in the feature classes, just domains.  I will give tech support a call.
