Map Package Creation Fails AGOL
1584
05-21-2020 03:51 PM
NWEdisonTeam
Hi
I am trying to create a map package on AGOL for offline use. I am using a tile basemap layer, and I am using a layer that is imported from a REST API service, which has been configured to go offline. Could the REST API service be causing the issue?
JonahLay
Are you using the Package Map geoprocessing tool in ArcGIS Pro? What does the error message say?
Jonah
NWEdisonTeam
Hi
No I am using the Arcgis Online “Create map areas” function. It doesn’t give me an error code.
[Tirrell Brown GIS Analyst Northwest Edison at Industrial Light & Energy, Inc. O 425.806.9200 | m 425.420.4672 | f 425.806.7455 DUNS: 039367516 CAGE: 3k3b9]
<https://www.facebook.com/Northwest-Edison-631874700167141/> <https://www.instagram.com/northwest_edison/> <https://www.linkedin.com/company/northwest-edison/> <mailto:tirrellb@nwedison.com>
Please consider the environment before printing this email.
This email may contain information that is confidential or attorney-client privileged and may constitute inside information. The contents of this email are intended only for the recipient(s) listed above. If you are not the intended recipient, you are directed not to read, disclose, distribute or otherwise use this transmission. If you have received this email in error, please notify the sender immediately and delete the transmission. Delivery of this message is not intended to waive any applicable privileges
