Make a field with a calculated value remain the same when a feature is updated
404
08-26-2024 01:02 AM
Mapnado
I have used an Arcade expression as a calculated field in Forms in Map Viewer. It’s working really well, but for my unique id field, I don’t want the value to change if the feature is updated. Is there a way to make a calculated value only calculate on insertion, rather than updates as well?
thank you!
RhettZufelt
MVP Notable Contributor
See this post.  It should get you on the right track.
R_
