Lookup Table in Featured Layer
2462
06-08-2021 02:33 PM
ludwigrh70
Hello! I'm an absolute newbie to ArcGIS and I hope someone can help me with a simple problem that I have.
I use ArcGISOnline and the Field Maps app on my iPad for birdwatching. That is, I use points to indicate where I have spotted a particular bird or a bird's nest. To make it simple, I use the template for collecting points. I then edit the table by adding fields for the name of the bird, a shortcut name for the bird name composed of 3 characters, and the habitat where I spotted the bird (forest, water, prairie, etc.).  I fill the bird name shortcut and the habitat with a pre-filled list so that I don't have to keep on typing these info. After which, I add this layer to my map.
 When I'm out in the field, I use the Field Maps app to add points whenever I spot a bird or a nest (or is the Collector app more suited for this?).
This is all working okay and I'm very happy with the results.  My question is, how can I automatically populate the bird name field based on the bird name shortcut?  I don't want to have to enter the bird name as well.  Instead, I want to keep a table of all bird names and use the bird name shortcut as the primary key and then use that to lookup the bird's name.
I have experience with databases, tables, index, and sql and I thought I could use a related table as a lookup I don't know if it's possible to create a dbf table using ArcGIS Online, and even if not, if it's possible to attach a dbf created in another app (Access, for example) to the layer and then use that as a lookup table.
I tried looking for a solution online but I couldn't find something simple to solve this problem and I hope someone can help me.
Thank you very much in advance!
DamonNelton
In regards to the relationship table building you need to build the layer outside of Online. I'd use ArcPro and then publish to online. Below is a wonderful video showing step by step how to accomplish
https://www.youtube.com/watch?v=Fo9tP9qkm8k
Designing Related Records in ArcGIS Pro for use in ArcGIS Online
This video demonstrates how to create a relationship between a feature class and a table in a file geodatabase using ArcGIS Pro. It has been created in combination with a blog post entitled "Related Data in ArcGIS Online" posted on GeoNet which is available at ...
