Loaded shapefile but no features showing
14964
20
04-29-2015 11:59 AM
JessicaKnight1
I have put a shapefile into a geodatabase and uploaded it to My Content. When I add it to the map, nothing shows up. At first I thought that maybe the projection was wrong or something. But if I open the table, there is nothing there. It works fine in ArcMap and if I download the .gdb from AGOL, it loads up with no issues in ArcMap as well. I have uploaded other data with no problems before. Any thoughts as to what's happening?
JessicaKnight1
Well I used the dice tool and also tried uploading as a tiled service and it seems to be working! Trying a second layer now to see if it works as well. If it does, I think this is a viable solution without taking too much processing time (I tried uploading it all as a raster before and it just churned and churned for a week without finishing, but this all took only an hour or so in total). Thanks so much! I'll be back if I hit some other roadblocks but all of this has been very helpful!
