Line Chart not Rendering in Pop-Up after updated
921
08-29-2024 07:20 AM
Heather_Hegi
I have this awesome pavement rating map where when you click on a pavement segment, it shows a line chart of condition over time. However, it won't let me add in 2024 data, whenever I try to update this line graph it breaks and the line doesn't render.
I tried taking the 2013 field out, incase there was a maximum number of fields it could show, but that didn't fix it. I tried creating the chart from scratch and that didn't fix it. I switched it over to Bar chart and it shows up fine, but I don't want a bar chart, the line chart makes the most sense for this data.
These are simple fields of data, no arcade or anything. The 2024 field is formatted the same as the rest, a Double. The layer lives in ArcGIS Online and I pulled this layer into ArcGIS Pro to add the field and populate it, does ArcGIS Online not like that?
Why is this not working?
Heather_Hegi
I got it working!
While changing it to a bar chart and back to a line chart alone didn't work, changing it to a bar chart and saving the Web Map, then changing it back to a line chart worked.
Heather_Hegi
I got it working!
