KML handling query
1968
07-20-2011 02:49 PM
ClemHenriksen
I am working with a Garmin file of waypoints and tracks. I have the data in two formats: KMZ and GPX. I way able to successfully drag-n-drop the GPX onto a web map using the web map viewer. Two Problems:
1) The KMZ file (which I have successfully viewed in Google Earth) was rejected with this error message:
The KML, http://file:///C:/Inetpub/wwwroot/test/CHRP.kmz, cannot be added to the map. It is either not available or you have entered an invalid URL for the type of layer you want to reference.
What is the quick and easy place to put KMZ to load it?
2) the GPX file loads both the waypoints and the track. This is what is in the file, unfortunately, it is not what I want. Can I use the web map viewer to delete the waypoints, leaving only the track? or do I need to delete the waypoints before I load the GPX file?
thx
MikeMinami
Esri Notable Contributor
#1 - this is a bug. Adding KML files to the map from My Content doesn't work. This will be addressed in our next update.
thanks,
Mike
