Juypter Notebook (via ArcPro) missing menu bar
13271
25
11-20-2021 02:55 AM
Abdulqadoos
So when ESRI's ArcPro was updated a week+ ago, the menu bar in juypter notebook disappeared. Now I have a hard time resetting kernels and doing basic functions (not stopping me but extremely annoying). Screenshot below.
Any ideas on how I turn it back on. I can see a flash of the menu with the Juypter logo when I first open a notebook, but then all I get across the top is "Edit, View, Inset, Cell, Help" and I know the View button isn't showing all the options it normally does.
Yes, the instance of Juypter notebook is installed as part of ArcGIS Pro - since it added it anyway, I've just been using that.
Thanks in advance. Link
Kelly
Juypter Notebook version 5.7.10 ArcPro 2.9.0
EugenioArima
This solution by MohandKETTOUCHE worked for me but I copied the two files (messages.css & messages.js)
from directory :
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\share\jupyter\kernels\ArcGISPro\default
to different folders
For the original arcgispro-py3 environment, the destination path is
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\notebook\static\custom
For my cloned environment, the destination path is
C:\Users\YOUR_USERnAME\AppData\Local\ESRI\conda\envs\YOUR_CLONED_ENV\Lib\site-packages\notebook\static\custom
Many thanks,
AaronLaver
@EugenioArima and @MohandKETTOUCHE  Thank you! I was able to fix it with MohandKETTOUCHE's method and EugenioArima's directory guidance.
Cheers.
SavageTrimble
@EugenioArima and @MohandKETTOUCHE Method Fixed....sort of and thank you for posting.  We were told this will be fixed in Pro 2.9.2.  Crossing fingers.
KoryKramer
Esri Esteemed Contributor
2.9.2 was released yesterday. See https://community.esri.com/t5/arcgis-pro-documents/arcgis-pro-2-9-patch-2-is-now-available/ta-p/1149...
The explanation on the Support site can be found here: https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDE0NDkxMw==
"This patch fix applies to the arcgispro-py3 environment. To get the desired behavior, users need to update to ArcGIS Pro 2.9.2, and re-create the clone (getting the fixes from arcgispro-py3) or run “conda upgrade jupyter_contrib_nbextensions” in any affected custom environments."
chris_del101
Posting here since this is the most relevant question I could find online.
I'm new to Pro and never use notebooks outside Pro so have no external environment setup.
I am missing the menu in Pro.
Pro Version 3.4.0
My short term goal is to toggle on line numbers. Is there a shortcut for this?
I do want this menu though, regardless of above. See missing:
EDIT: Realized the menu seems to now be that little keyboard dropdown. Show line numbers exists there. So question withdrawn.🙂
LELI
I have the same issue. I don't know why the little keyboard dropdown replaces the menu bar. The dropdown is very difficult to use. And this is a difference than normal Jupyter. Why ?
