Item Details & Export from "More Options"
708
07-11-2024 08:19 AM
ChristopherHoward
I am running into an issue with the ability to export a layer while in my map via Map Viewer Classic.
The option within "More Options" to export is gone. I also noticed that "Item Details" has been replaced with description.
My layer is set to be exported by all. I have made no setting changes or edits to these layers in the time from when I had the ability to export to the time updates rolled out, to now.
Does anyone know if this is a result of the updates? I questioned if it was because of user type but it is stated no functions would be lost with these updates. Even when I click save layer, I cannot export (cannot change any settings, etc)
ChristopherCounsell
MVP Frequent Contributor
Try using the new map viewer?
Classic is on the way out and you might get better results looking for assistance migrating to the new map viewer over troubleshooting changes/issues with classic.
