Issue with the print widget in arc online
2167
6
05-03-2017 03:13 PM
JoseMedrano
I am having trouble with the print widget for ARC Online.  Exported images return with "override" in the legend.  Anyone else have this issue and know of a solution?
KellyGerrow
Esri Alum
Thanks Jose,
This is currently a limitation in the print service with specific smart mapping styles , such as counts and amounts. We are currently researching the best way to resolve this issue.
There is an enhancement logged with Support in regards to this issue:
ENH-000103123: Enhance the Printing Service to support printing sym..
I'd suggest contacting support to be attached to the enhancement for tracking purposes. I'll also update this post when we it will be addressed.
-Kelly
KellyGerrow
Esri Alum
Can you share a screenshot of the issue or the webmap?
Is one of your layers named override?
-Kelly
JoseMedrano
Kelly,
Thanks for your response!  No layers are named override.  The problem occurs when attempting to print layers that utilize the "counts & Amounts" symbology.  See attached,
-Jose@
KellyGerrow
Esri Alum
Thanks Jose,
-Kelly
MaryLong
Hi Jose,
Did you change the symbology in the webmap prior to adding the map to the basic viewer? Or was it published from Desktop with this symbology?
JoseMedrano
Hey Mary,
I symbolized in the webmap, then added to the basic viewer.  Is publishing from Desktop with symbology a viable workaround?
Thanks!
MaryLong
Hi Jose,
Based on the enhancement Kelly mentioned, it appears that the issue is associated with changing the symbology within the webmap. If you have the ability to change the symbology in Desktop and then publish to ArcGIS Online, I would suggest trying that.
