Is there any way currently to remove the Directions button from the toolbar in a web Map
1103
08-04-2016 06:44 AM
GlenSine2
I am trying to publish web maps for Collector for field use.  Problem is, we don't want our users to utilize the routing capabilities.  When I uncheck routing in the properties, the directions button still activates and allows directions and routing to function.  (I may be wrong, but this is using the routing functionality and credits for AGOL, correct?, if not, what is it using to route?)  Our biggest concern is overuse of the service, when most of our vehicles have some sort of navigation already, whether it is through mobile device or navigation unit.
Glen
MichaelMiller2
In AGOL, click on the map in you content and select "view item details". Click the "Settings" tab and scroll down and you can disable the Routing functionality.
