Is there a way to reorder the fields in a "View" of a feature layer
667
5
05-14-2025 04:32 PM
sandra555
Hi All, I have made a "View" of my feature layer so that I could select a subset of fields that will eventually display in my dashboard's Detail element. Is there a way to reorder the way the fields display in the Detail element? I know how to do it in a web map (in the pop-up interface), but can not find something similar for a feature layer that is not a web map. Is this possible? Thanks.
PeterHodkinson
If you select Layers on the left side pane you should see the options on the right side pane become active
PeterHodkinson
Hi @sandra555 have you tried adjusting the configuration in the Visualization tab of the feature layer's item details page?
sandra555
Thanks Peter. I looked there but I do not see an option to change the field order. Most of the options on the right (that are available in a web map) are greyed out in the View.
PeterHodkinson
sandra555
Thanks Peter! I thought I had the layer selected, but it wasn't.
PeterHodkinson
No problem at all! Glad I could help 🙂
