Is there a way for end users to submit a shape (row) to an existing feature layer in ArcGIS Online within WebApp Builder??
574
12-06-2022 09:06 AM
Labels (2)
Server
Essentially I want an end user (who is using a Web App Builder application, or any of the suite of other online apps, like collector, survey123 etc.) to be able to submit a pre determined shapefile or feature into ArcGIS online. This shape would then be added to an existing feature layer that is stored on AGO. The shape could then be used for analysis within a web app builder application.
Unfortunately the "Add Data" widget only adds data to the application, and doesn't allow many of the widgets to access the data to perform analysis, so it doesn't exactly help. Essentially I need the same functionality of the "Add Data" widget, but the data will actually be added to a feature layer permanently, which can then be used to select features with the batch editor.
