Is there a performance loss on a service containing a definition query?
4235
11-05-2014 05:33 AM
BrandonKeinath1
It looks like I am able to publish services from data that contain definition queries.  Is there any performance loss doing it this way rather than a separate exported feature class?  You could also expand it to me wondering what the pros/cons are for publishing services with definition queries.
Brandon
XanderBakker
Esri Esteemed Contributor
I guess it will be pretty fast if you set the right indexes, but publishing he data the corresponds to the query only, will probably be a little faster.
BrandonKeinath1
Giving this a boost to see if anyone has any opinions.  I successfully published a service with a definition query but still looking to see what effects this might have long term
XanderBakker
BrandonKeinath1
Hi Xander,
Which indexes should I be on the look out for?
Brandon
XanderBakker
The fields you are referencing in the query should have an attribute index to query data on attributes faster:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
BrandonKeinath1
Thanks Xander,
That's very helpful advice.  I will add that into our process documentation.
Best,
Brandon
