Is Manage Feature Template Coming to the New Map Viewer?
2754
9
11-13-2023 08:46 PM
Labels (2)
tiztrain
Hey all,
Looking to get an update whether the 'Manage Feature Template' functionality is coming across from the classic map view to the new one?
Or is there a better way already to manage this in the new version?
EmilyGeo
Hi @tiztrain
Yes, providing support for managing templates in Map Viewer is on our future road map. In the mean time, as you pointed out, you can use Map Viewer Classic, or the Field Maps Designer app.
To manage templates in Field Maps follow these steps:
  1. Open Field Maps
  2. Select a map
  3. Select a layer
  4. Open the 'Templates' tab,
  5. You'll see a  list of existing templates.
  6. To create a new template, click Duplicate and change properties as needed.
  7. To edit an existing template, select the template you want to modify and make the desired changes.
  8. To delete a template, select the template and click the 'Delete' buttonl
Hope that helps!
EmilyGeo
Hi @tiztrain
  1. Open Field Maps
  2. Select a map
  3. Select a layer
Hope that helps!
tiztrain
Oh wow did not even realise templates existed in Field Maps Designer app. Thanks @EmilyGeo
StefanUseldinger
Do You know, when templates can be created in the ArcGIS Enterprise Field Maps Designer app?
GISUser74305830
Where is the "Add Template" button?
MDB_GIS
The fact that this extremely basic feature is still not in the default map viewer is mind blowing.
EmilyGeo
Just following up in this thread to let you all know that support for managing templates has been added to Map Viewer as of the Feb 2025 update to ArcGIS Online. You can check out this article to learn more. Happy mapping! https://www.esri.com/arcgis-blog/products/arcgis-online/data-management/optimize-editing-with-templa...
MDB_GIS
Great news. Thank you!
Edit: I'm guessing this change isn't in portal yet? I still don't see this option.
EmilyGeo
This is available at 11.5. To edit a layer's feature templates, you must be the owner of the layer or an administrator. The layer must also be a hosted feature layer.
MDB_GIS
Gotcha. I'm on 11.3. Looking forward to upgrading.
