Is it possible to load a Thunderforest Open Cycle Map as an AGOL basemap?
2969
06-04-2017 01:08 PM
deleted-user-zc_J5JescS67
I have tried entering the API I got for Thunderforest Open Cycle Map to use as a basemap in AGOL, but all it turns up is a blank page. I've been able to open it up in other platforms - leaflet, qgis2web plugin - but it won't work in AGOL.
Any advice? thanks
XiaolongFeng1
Edward,
Just use this URL:
https://{subDomain}.tile.thunderforest.com/cycle/{level}/{col}/{row}.png?apikey=b60c02dc2f1c476983e78e9b863fc6d1
Do not remove those words: "subDomain", "level", "col", "row". Just copy the URL above and paste it, then it should work.
XiaolongFeng1
Hi Edward,
Yes you can add the Open Cycle Map to ArcGIS Online, you just need to alter the URL a little bit.
From the provided example in Thunderforest's page, the url is like this:
https://{s}.tile.thunderforest.com/cycle/{z}/{x}/{y}.png?apikey=<insert-your-apikey-here>
But for ArcGIS Online, you need something like this:
http://{subDomain}.tile.opencyclemap.org/cycle/{level}/{col}/{row}.png
You can follow the steps here to add a tile layer to the map: Add layers—ArcGIS Online Help | ArcGIS
When you input the URL, you should input this:
https://{subDomain}.tile.thunderforest.com/cycle/{level}/{col}/{row}.png?apikey=<insert-your-apikey-here>
Then you need to define the subDomains - in Thunderforest's case, it should be "a,b,c".
Then you'll be all set and able to use the base map. Enjoy!
I have tried every form of what you have suggested and nothing works, I
just get a blank basemap, repeatedly. OSM seems to work fine.... Here's my
API key along with the URL Thunderforest provides. Could you let me know
exactly what should work, in case I'm making some minor mistake? I'm sure I
did everything else correctly - add tile layer from web, set extents, etc.
https://{a,b,c}.
tile.thunderforest.com/cycle///.png?apikey=b60c02dc2f1c476983e78e9b863fc6d1
Thanks!
XiaolongFeng1
Edward,
Just use this URL:
