Invalid tenant Id. Unable to find tenant in database. Invalid tenant login
6721
5
11-18-2015 12:04 AM
zakatpp001zakat
I'd just created my trial account. When I tried to add data this error message came out.
"Invalid tenant Id. Unable to find tenant in database. Invalid tenant login"
How do I solve the issue??
KellyGerrow
Esri Alum
This issue was resolved earlier this morning. Are you still experiencing any issues?
RebeccaStrauch__GISP
Is "tenant id" one of your fields? If so, I would recommend eliminating spaces in field names (change it to "tenantID" maybe).  I would also check to make sure that you don't have invalid data within the field.  If that isn't one of you fields, then I have not seen that error.
how are you adding the data? and can you post a sample of the data for others the test?
I just noticed this thread
Re: Issue with publishing a Feature Service Which says it should be fixed now.  My guess is it had something to do with the update last night.....or specific to the free accounts, based on comments on that thread.
KellyGerrow
Esri Alum
zakatpp001zakat
Thank you very much. Yes the problem is solved
AlanCunnane
Hopefullly this is the right place to put this.  I create a new trial account and all seemed to be going well until I went to create a hosted feature service and I get the following error:
My subscription ID is: 6681056109.
Hopefully this is a quick fix??
