Hi all,
I am setting up a field data collection tool with FieldMaps and Survey123 connect. Registration is done with FieldMaps. Monitoring is done with Survey123 connect. To link the registration and monitoring data, I use the solution to copy the globalID from FieldMaps to Survey123.
I used this solution because the data collection capabilities of FieldMaps are fairly limited and by far not sufficient for our needs. Survey123 connect (ODK) does provide the capabilities that we need but is fairly limited for its mapping capabilities. The relation between the FieldMaps form and Survey123 form is created by a pop-up URL. This seems to work fairly well during the first (online!) tests.
Now, here comes the issue: I want the enumerators to carry out both a registration and a first monitoring in the field at the same time. They work very remote and completely offline (no WiFi or GSM signal). Testing it offline I realised that the URL pop-up (and the globalID) is only generated at the server level.... If this is indeed the case this would means that the enumerator first has to submit the FieldMaps data before he/she can start monitoring that data with Survey123... Even if I would create a 'local ID' (for example an ID based on site name) and copy this to Survey123, this still would not work since the URL to Survey123 is only created when FieldMap data is submitted. Am I correct? If not, how could this be solved? Are there any other people that use this solution (using FieldMaps + Survey123 at same time before submitting the data in an offline situation)? good to hear experiences and possible solutions. Thanks!
