Inconsistent "view" count
2259
5
06-04-2013 07:32 AM
SandyWoiak
I would like to keep track of the number of visitors to my web maps and web mapping applications. I've noticed that the "view" counts seem to reset at times, while at other times they appear to be a running total. What's going on with this? Do these counts get reset periodically and if so, how can I see total views?
MikeMinami
Esri Notable Contributor
The view count shouldn't be getting reset. It may get reset if you delete an item and recreate it.
Is it happening with specific types of items? What are you doing when you notice it gets reset? Can you provide a set of steps to reproduce the problem?
Mike
SandyWoiak
I haven't made any changes to the Web Map "Fairfax Trail Buddy" (user name = FairfaxCounty) since May 15. Yesterday the view count was 2,881; currrently it's 603.
MikeMinami
When you look at a specific item, the count is correct.
http://www.arcgis.com/home/item.html?id=37d010769e8c4d09a81198f1ce31a17a
Unfortunately, there is a known issue where the count is incorrect in searches, like this.
http://www.arcgis.com/home/search.html?q=owner%3AFairfaxCounty&t=content
The count gets synced up whenever you update the item.
Mike
JamesCucinelli
Any idea on when this will be fixed?
James Cucinelli
MikeMinami
This is a challenging problem for us to fix actually, thus, we don't have a release date set yet. Sorry.
Mike
