Illuminating polar regions in 3D webscene
3933
04-12-2016 07:08 AM
CooperThomas
This question regards the webscene lighting model. I’m currently working on a Story Map Journal that focuses on human activity near the north pole. As the user scrolls through blocks (or "chapters") of written content, a companion map dynamically updates to show relevant data and areas of interest.
I'd like to use a webscene instead of a webmap for this project in order to minimize geographic distortion, to provide a sense of scale, and to allow for the display of features that wouldn't be visible with a polar stereographic/orthographic projection. Unfortunately, however, it is seemingly impossible to illuminate the entire north pole (or south pole, for that matter) using the webscene's lighting system. Even if I set the time to high noon in June or July, half of the pole remains obscured in darkness. I appreciate the realism, but in this case, it prohibits me from creating an effective webscene.
Is it possible to disable the realistic lighting engine so that the entire planet is illuminated, as in ArcGIS Earth, Google Earth, Google Maps, Bing Maps 3D, etc.? I suspect not, but I thought I'd ask. If any folks on the webscene product team are here, I’d kindly ask you to consider adding this feature in a future update, as it would greatly increase th !e utility of the tool.
Thanks!
KristianEkenes
No, you currently can't do this. It's being talked about, but the only way to modify lighting is by setting the date.
KristianEkenes
CooperThomas
Thanks for your swift response, Kristian. Do you know if this feature will be included in a future update?
KristianEkenes
This hasn't been determined yet. Given this scenario, we'll discuss it some more.
