I am using world imagery online and i have a internet speed of 10Mbps,but image is taking too much of time to open in arcmap 10.2 and same is the problem when i zoom in the base maps especially on the conic and polar projection systems
4071
12
08-04-2014 07:23 AM
ranvirsingh
I am using world imagery online and i have a internet speed of 10Mbps,but image is taking too much of time to open in arcmap 10.2 and same is the problem when i zoom in the base maps especially on the conic and polar projection systems@
DanPatterson_Retired
Please shorten your title and provide some tags
ranvirsingh
i have described that i have slowness issue with the world imagery working in arcgis online ,when i open it in arcmap,it is taking too much of time.I have a internet speed of 10mbps(especially on the polar and conic projections)
ranvirsingh
ok
HemantAngarkar2
I have few questions;
1) Is it slow only for particular imagery/area?
2) Have you tried different browser?
3) Do you have another machine with same internet connection, have you tried from that machine?
You can try few things like clearing temporary memory, keep enough space for virtual memory in C:\ drive.
ranvirsingh
actually arcmap is installed on the server.
ranvirsingh
It is not slow for a particular area
By diffrent browsers what are you trying to say.please elaborate.
I have fifteen machines with same internet connection.
so suggest some thiing
HemantAngarkar2
Ok, so you are accessing imagery from ArcGIS Desktop Application! Forget browsers. From many machines you have the same internet connection, is the difficulty faced for that imagery? I mean try a different machine with arcgis to access the imagery.
Or as Jorge correctly pointed out, on the fly Re-projecting could be the issue.
JorgeOrellana
I've had big issues with this. There can be a few contributing factors to your issue. The biggest ones I know are
1. If you are on your organizations network, there could be some throttling being done that is slowing down your connection.
2. Re-projecting on the fly WILL slow down the imagery's (and any data's) draw time. I had previously ran a test of an MXD with two data frames showing he same extent and only having ESRIs World Imagery, one in Web Mercator and another on in a NAD 83 UTM zone and the draw times were drastically different, often Web Mercator would draw in ~5 seconds, while the one in UTM Zone would be averaging 45 seconds. There's no know cure to this issue, other than changing data frames to WGS Mercator, but that is not recommend for any purpose other than displaying data.
ranvirsingh
i have to use different projection systems for the diffrent maps,i am using many coordinate  systems such as conic,polar,utm,wgs1984,that depend upon the projection used in the raw maps,i have to open two to three dataframes at a time and this slowness is really affecting the production of the project.@
