I am a bit new to ArcGIS online. I was trying to add shapefiles to ArcGIS online using "Add Layer from File" and the size of shapefiles was approx. 2 mb.
I am facing error i.e. as per the screenshot above i.e. the data set is too large. How should I add my data which is only 2 mb on ArcGIS online so that I can view it.
Please help me out regarding this issue. I would be thankful to you for this.
The shapefile is compressed into a zip file?
http://doc.arcgis.com/en/arcgis-online/create-maps/add-layers.htm#FILE
Can you publish hosted feature layers?
http://doc.arcgis.com/en/arcgis-online/share-maps/publish-features.htm specifically ( http://doc.arcgis.com/en/arcgis-online/share-maps/publish-features.htm#ESRI_SECTION1_49CE0570C3BA4AD...)
of if it is for testing purposes, try a subsample of your file.
Do you only have a free subscription to ArcGIS Online?
Do you have access to any ArcGIS Desktop software? How many features are contained in your shapefile (there is a limit of 1000 features)? Is it possible to attach the shapefile as ZIP to this thread to examine it?
Echoing Dan & Xander's questions:
https://mega.nz/#!MqY00KDY!MK0PhooayIyb2X8BLsh6Gsb-e-hmZwmQvtb7OXiBCnY
Above is the link for the sip file for my shapefiles. Please have a look at it regarding how to open it in ArcGIS online. I shall be thankful to you for this.
There are two shapefiles with more than 1000 features that need to be split into separate shapefiles. It's best to manage each shapefile in its own ZIP file. Try with the ZIP files attached.
Check the previous responses
As I noted 2 days ago, and other have previously noted...
Try the suggestions already offered or indicate why they haven't or aren't working.
Hi Dan Patterson, maybe the OP does not have access to Desktop or other software that allows to split the shapefiles. One thing is for sure; there are two shapefiles with more than 1000 feature, and you cannot add those to AGOL.
Hi Xander Bakker the OP has other questions indicating otherwise https://community.esri.com/message/737697-how-to-reduce-tiff-file-size
Good research!
