How to test spatial correlation between two layers
7155
10-08-2015 11:44 AM
WeilinZhou
I have two layers, which visually have spatial correlation. Does anyone know if ArcGIS has any analysis test to test if there is any significant correlation between those two layers?
Tags (1)
DanPatterson_Retired
Did you examine or rule out any of the tools in this link
http://doc.arcgis.com/en/arcgis-online/use-maps/perform-analysis.htm
ChrisSmith7
Honored Contributor
Is that available in ArcGIS Online?
ChrisSmith7
Honored Contributor
I believe it's just with ArcMap and ArcGIS Pro - not ArcGIS Online! I wanted to make sure they were aware, just in case it was helpful.
