How to tell Workforce Which Column of Feature Layer to Use In Location When Creating Assigment
1172
06-26-2018 06:18 PM
BenVan_Kesteren1
Hey,
I have just created a feature layer online, and this feature layer has hundreds of features, and there is about 20 attributes in this table for each feature.
I want to select a feature on the web map, and assign the task to a worker. When I select a feature and click create assignment, it auto populates the LOCATION field with the feature layer name. I am wondering if I am able to modify what data is inserted here, as I would much prefer to pass an assetID accross.
Is this possible?
Location Field Question
MattVRobinson
The location field in Workforce when creating an assignment uses the Pop-up title for that particular feature layer from the Workforce Project web map. If you add the assetID field to the pop-up title, it should pass through when creating an assignment.
Check out the Project Creation Tips > Tip: Customize feature pop-ups here:
Tips for project owners—Workforce for ArcGIS | ArcGIS
Generic Text in Pop-up Title:
Generic
Field Name in Pop-up Title:
ID
MattVRobinson
Generic
ID
BenVan_Kesteren1
Hey, Thanks for the detailed reply.
Yeah it seems to have eventually worked fine, but it was not applying the changes instantly for some reason. It wasn't until I came into work the next day that the changes filtered through entirely.
Cheers!
