How to symbolize a feature based on values from multiple fields using Arcade?
1444
04-14-2020 07:23 AM
HMorrell
I am trying to symbolize a map in ArcGIS Online that will be used in Collector.  I am working with points that have 2 attribute fields of importance; "WorkType" and "Status". I am trying to write an Arcade expression that will do the following:
If "Status" equals 'incomplete', symbolize using unique values in the "WorkType" field.
If "Status" equals 'complete', symbolize the points with a green check mark.
Any help is greatly appreciated.
VictorCoelho
I believe this Blog have the information you need to symbolize your map: https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/use-arcade-expressions-to-map-your-i...
HMorrell
Thank you Victor. Have a great day.
