How to stop Text Field reformatting dates?
3133
11
10-31-2023 05:45 AM
Labels (2)
Savannah2019
So I've noticed that text fields in arcgis online are reformatting dates. How do I stop this? I made it a text field for a reason. I want "October 2023" to appear, not "10/1/2023". The only way I can get it to stop doing this is to put in extra text, but I don't want that.
Please see the photos:
What I've written:   Savannah2019_0-1698756214937.png
What appears in the pop-up:  Savannah2019_1-1698756253212.png
Help!
RussRoberts
Esri Notable Contributor
I think I found the issue
- If you can open the web map in https://ago-assistant.esri.com/
- Check the field under fieldinfos and see if the property format exists.
- If a format exists and it says shortdate
- if its there you can delete it from the JSON in the assistant
What caused this? I think possibly the original map created had the layer being used the field was originally a date field. The layer was overwritten and the field was changed to a string field but the web map still contained the date formatting.
RussRoberts
Can you share your map and I can take a look? thanks!
Savannah2019
Unfortunately, no. It has some internal information, so I can't.
RussRoberts
Are you setting the formatting on the fields
Savannah2019
It's a text field, not a date field, so I don't even have that option. That's what is so confusing to me!
Text field: Savannah2019_1-1698759060407.png
Formatting options:  Savannah2019_0-1698759035189.png
I can add additional text and it'll stop trying to convert it to a date, but it isn't ideal:
RussRoberts
Can you see what the service returns for that feature through the REST endpoint? I checked against a text field and the string October 2021 was not adjusted with formatting. If you can create a repro case using some other data or map that would be great too.
Savannah2019
I tried to create a new point feature class and it's not doing it, so I'm really not sure why this one just started acting up. I assumed it had to do with the most recent AGO update, but if it's only this feature layer that's affected, I'm at a loss.
Can you tell me where to look for the REST endpoint? Should I be looking for something specific? Looking at the rest services page, the only line about it says:
  • ScheduledStart (type: esriFieldTypeString, alias: Scheduled Start, SQL Type: sqlTypeOther, length: 50, nullable: true, editable: true)
RussRoberts
Savannah2019
Thank you! This worked beautifully 😄
I think yes, when I first created this, it was an actual date field, but I realized that wouldn't work in all cases.
Savannah2019
Ok- update: I put the layer in a new map- no issue. It's something to do with the map it's already in. Any ideas what could be causing it? It's not in an attribute expression, it's just selected from the fields list.
