Is there a good way to see which layers in your web map are time enabled, other than going to each layer's settings?
This seems to be the only way to permanently disable to automatic time slider upon opening a map. Is there a way to remove just that function so when anyone opens the map, it doesn't automatically appear, even if data in the map is time enabled?
