How to secure services with SSO login?
369
10-15-2025 06:23 AM
RachelPasser_RFA
My program is developing ArcGIS dashboards with record-level health data. We only want users to access the data through the app. This is possible by following this workflow: https://support.esri.com/en-us/knowledge-base/how-to-limit-access-to-secured-hosted-services-or-map-...
My Esri account has a username and password, so I can do this successfully. However, my employee has a newer Esri account in my organization and he uses SSO login. So when he gets to step 3B, he doesn't know how to move forward. What would you do?
Tags (3)
RyanUthoff
MVP Regular Contributor
It's not possible to store credentials with services using SSO accounts. You can only do it using built-in accounts (like yours).
What we have to do is create a built-in Portal "service account" that is used specifically for sharing services where we want to store the credentials with the service.
RachelPasser_RFA
Thank you. I'm not sure I can create a built-in Portal "service account" because my organization doesn't use Portal.
RyanUthoff
Sorry, I said Portal because that's what I use, but that also applies to AGOL as well. You'd need to create a built-in AGOL account.
RachelPasser_RFA
No worries! I think if we implement this solution more frequently that is something we could arrange. Appreciate your insight. 🙂
