How to revert symbology changes in Webmap?
9073
18
12-11-2018 01:10 PM
ZorbaConlen1
Hi. I have added a feature layer to my webmap, configured a bunch of things, like popup, etc... Also, I configured the symbology to override the default symbology I had created in Arcmap. Now, I have decided that I want to switch back to using the default symbology of the map service. There does not appear to be a way to do this via the user interface. Am I missing it?
I'm aware that I could simply delete the service from the map, and re-add it in order to go back to the original symbols, but this is problematic. I would then loose all of my configurations. This could be extensive, especially with highly customized popups.
ZorbaConlen1
Awesome! Thanks Mike.
MikeMinami
Esri Notable Contributor
Zorba Conlen At the next update of AGOL, you will see a new option that allows you to use the default style set on the layer.
Your feedback helps make AGOL better!
Mike
AllenScully
Hopping on here to ask if this works in Portal (10.7.1) as well? I see the 'Set Default Option' as well but it is not doing quite what I thought.  I can troubleshoot, it may be another issue on our end, but wanted to confirm that in Portal, clicking the 'Set Default Option' supposed to revert back to whatever the service-level symbology is?
Thanks -
Allen
KellyGerrow
Esri Alum
HI Allen,
That is correct. I'd suggest getting in touch with tech support if this isn't behaving as expected.
-Kelly
g_maps
Hi @MikeMinami
Was this functionality lost during the deprecation of map viewer classic?
MikeMinami
For feature layers, you can reset a layer to its source. Here's a doc link.
by Anonymous User
Not applicable
Mike, Kelly, Katie and team...thank you!!  This saved me much time today. I'd been keeping an eye on this. Thanks for tracking and implementing. I just used it and it worked perfectly.
Boyang_Wang
I am wondering if this "set default style" functionality is available in new Map Viewer.
Also, is it possible to set label style to default service level style?
Marc_Patti
Hi All,
I also noticed that the "set default style" functionality is not available in the new Map Viewer. It is still present in Map Viewer Classic, but the symbology settings are not carried over to the current Map Viewer after saving changes.
Are there any plans to incorporate this as a working feature in the new Map Viewer? It would have saved me a lot of time to have this feature working.
Marc
