How to remove the OAuth 2.0 in Web Map App
4166
6
09-12-2023 11:05 AM
Da-WeiLiou
Hi,  I have a Web Map App.  Recently I see a "Oauh 2.0" in the Web Map App Overview page.
There is description saying "A registered OAuth 2.0 application.  May use premium or subscriber content" when I click this "Oauh 2.0) icon.
How do I know which of my content is "O Auth 2.0" application, and how do I remove this ?
Thanks for any help!
Da-Wei
Omar_A
by Esri Contributor
Sharing this documentation that might help clarify your questions with information about OAuth 2.0, the industry-standard protocol for authorization.
https://developers.arcgis.com/documentation/mapping-apis-and-services/security/oauth-2.0/
BernSzukalski
Esri Frequent Contributor
As I (somewhat dimly) recall, back around the June update, perhaps earlier, there was a behind the scenes change that exposed the OAuth badge on some applications. To remove that, you can go into the app settings and unregister it.
Da-WeiLiou
Hi, Thank you so much.
Do you know where can I find those options ?  I cannot see this in my web app setting page as the following.
Thanks.
Da-Wei
BernSzukalski
If the app is registered, you will find that in Settings > App registration:
EvanHayes
Was solution ever found for this?  I recently ran into the same issue with an application I use frequently.  Out of nowhere, somehow it now has the OAuth 2.0 lock, and I don't see those settings shown above to remove it.
Da-WeiLiou
I just created another webapp builder to replace the one has problem, and it solved.
But I also created an experience builder app to replace the old one.
Da-Wei
