How to remove the editor tracking info from the Popup window?
5485
12
02-24-2016 12:37 AM
YovavZohar1
When you enable Popup on a Feature Layer that has Editor Tracking turned on, the Popup window contains information regarding the editor of the identified feature.
I want to display the popup without that info and couldn't find any option to do so (tried all the basic customization options).
Is there a way to create such popup (without server)?
Thanks in advance,
RussRoberts
Esri Notable Contributor
This is something we are actively working on and is planned to come in a future release.
DanPatterson_Retired
can you not disable tracking for that layer Filter edits—ArcGIS Online Help | ArcGIS
YovavZohar1
Yes, I can, but that's neutralizes the Editor Tracking functionality which is needed in the first place.
The help suggests that you can disable it is for that layer, does it disable it for all layers then?
YovavZohar1
I'm not sure I understood your question correctly.
There's possibility to disable the Editor Tracking for the Feature Layer and then the info doesn't appear in the Popup.
I'm looking for a solution that lets me keep the Editor Tracking active, while not displaying it in the Popup.
I see no option for that in the interface, that is probably a design issue of the interface, you should check internally within esri and see if hiding it could be set as an option.
BenVan_Kesteren1
Does anyone know if this has been requested of ESRI on the Ideas page? I am now trying to remove that line from my pop ups.... cannot seem to find a solution:
RussRoberts
HeatherStudley1
Is there an Ideas page for this topic so we can track progress?  It's been a year since the last reply.
BenVan_Kesteren1
They were actively working on it... just not very hard! haha
