How to overwrite a hosted table that is joined to a hosted feature layer.
682
03-11-2024 11:43 AM
JanelleShank
Hello, I am currently trying working with a hosted table that I would like to join to a hosted feature layer. Does anyone know if it is possible to join the hosted table to the hosted feature layer while still being able to overwrite the hosted table and have the data update on the new join? Open to all suggestions and workflows!
Thank you,
Janelle
clt_cabq
I have a hosted table related (not joined, so a little different possibly) to a hosted layer that i overwrite periodically from arcgis Pro, seems to work ok.  Some of this may depend on the fields you are using to make your join - if you are using GUIDS for this purpose that might be a problem, but if you are using a field in either table that isn't a GUID then it may still work. I'd recommend you test this on a copy or a dummy dataset before you try it out on the real deal though.
