How to have a number and string format in the same field show in the same popup using Arcade.
2385
08-28-2023 03:50 PM
aduyvesteyn
Hello there I have seem to come into an issue regarding an arcade popup. Within the same field in an attribute table there is both a nine digit number that needs to be formatted like (000-000-000) and a string value that does not need to be formatted in that sequence. Is there any arcade expressions that I could use to help me solve this issue so the pop up does not appear like it does in figure 2.
Figure 1. Attribute table example
Figure 2. Pop up Formatting issues
Thank you and I appreciate your feedback.
JohannesLindner
var txt = $feature.TextField1
if(IsNaN(Number(txt))) { return txt }
var parts = [
  Left(txt, 3),
  Mid(txt, 3, 3),
  Right(txt, 3)
return Concatenate(parts, "-")
Have a great day!
Johannes
JohannesLindner
var parts = [
  Left(txt, 3),
  Mid(txt, 3, 3),
  Right(txt, 3)
Have a great day!
Johannes
aduyvesteyn
Thank you so much!
