How to enable feature searching in my Web Map? Options missing!
6084
10
04-05-2016 04:29 AM
TheoFaull
I have a web map on arcgis online. I have uploaded a zipped shapefile containing polygons with a mostly populated attribute table. I want the end user to be able to run a search when using my map, so they can search for info within this feature.
Using ESRI's tips, they say go to the 'about' button on the left> then 'more details'> then 'edit' map. At the bottom under properties> application settings, there is meant to be an expandable setting called 'find locations'. But I can only see Routing, Measure Tool and Basemap Selector. ???
I'd really appreciate some advice!
TheoFaull
Thank you. I feel all has been explained for now.
