How to control label overlap in web map
2114
01-27-2025 03:43 AM
Labels (3)
DevakalaiselvanS
Yogesh_Chavan
Hi @DevakalaiselvanS,
What is getting overlapped? In your screenshots the two labels are seen separately.
Can you explain a bit more on your expectations?
DevakalaiselvanS
When publishing in ArcGIS online, both labels appear in the same spot even though they are independent in ArcGIS Pro.
DevakalaiselvanS
How to apply label position in ArcGIS online
RussRoberts
Esri Notable Contributor
Polygons are currently limited to the centroid inside the feature but you can apply an offset to that centroid position.
