How to click on an area of the map and have a label show up?
731
11-17-2023 12:52 PM
AngelaCox
I have tried to make my own map; copying (4) other map resources I found. Here is what I am working on;
https://www.arcgis.com/home/webmap/viewer.html?webmap=7388427f6ae34e64b56e718ea3cc05c5
Here are the (4) Maps I have copied into mine;
https://geohub.lio.gov.on.ca/datasets/lio::municipal-boundary-lower-and-single-tier/explore?location...
https://geohub.lio.gov.on.ca/datasets/lio::geographic-township-improved/explore
https://geohub.lio.gov.on.ca/datasets/lio::conservation-authority-administrative-area/explore?locati...
When you are using the individual (4) maps above, when you hover over an area a label / name will appear. How do I get these to show up on my map?  Are these attributes?
thank you very much in advance.
Tags (4)
JonathanNowlan
Hi Angela,
You can configure the pop-up in ArcGIS Online to only show the fields you are interested in. Here's a link to documentation about Pop-ups.
On the lio map they are pulling information from a field called: Official_Municipality_Name
