How to change text and style for the Filter buttons on the feature info widget
486
03-16-2022 03:34 PM
RobertBuckley1
In my Experience I have linked a map and a feature info widget. The Feature Info widget has a filter built in.
Unfortunately the standard text on the two buttons to set the filter and to remove it are too long and are cut off. There is also no style settings attatched to the filter so I can't change it to a shorter or smaller text. In the "online assistant" there is also no json code which points to this entity.
Is there another way to change these properties of the feature info filter?
