How to change location on a feature in a hosted feature layer.
1107
04-18-2017 06:01 PM
TawnyLochner
The lat long on a feature were changed through the data tab on a hosted feature layer, how do I get this to be reflected in the location without redoing the entire map?
Thank you
KellyGerrow
Esri Alum
Hi Tawny,
How did you publish your data? From a CSV file or a shapefile?
Kelly
TawnyLochner
Through a csv file.
KellyGerrow
Esri Alum
Hi Tawny Lochner‌,
The lat and long fields in a csv are used to create geometries at publishing time. In order to run the process where a location is assigned to an lat and long field, the publishing process will need to happen.
If you are using a CSV file, you can update the csv file, and overwrite the service, this will re-assign locations to the values in the CSV.
-Kelly
