How to change a symbol color in a WebMap?
907
03-31-2025 07:46 AM
Almaz_Naizghi
Hello,
I choose the symbol in the following web map from the "Point of Interest" collections. I would like to change the color of the symbol and as you can see it in the print screen below, it is in active.
What can I do to change the color?
Thank you for your help.
KenBuja
MVP Esteemed Contributor
The Point of Interest markers use preset colors, so you'll have a limited choice in colors. You can use the Pins markers under the Vector Symbols to give you more control over color, transparency, etc. If you want that exact pin shape, you can use the Animated shape but turn off the animation.
KenBuja
Almaz_Naizghi
Thank you for your help @KenBuja!
