How many credits consume just when publish a scne layer pacage from slpk.
1298
07-01-2024 11:30 PM
hitsujir_dev
I was able to publish the same slpk with my account having publisher role and assigned credits, but the other acccount having publisher role, but not assigned credits, did not do it.
I procedd this step in ArcGIS Online.
>Publish from a scene layer package
https://doc.arcgis.com/en/arcgis-online/manage-data/publish-scenes.htm#ESRI_SECTION1_B1CE8603397E4B3...
Also, I captured the network traffic and it shows me the error message below.
 "error": {
  "code": 400,
  "messageCode": "PUB_0048",
  "message": "User '<username>' does not have enough credits to perform this operation",
  "details": []
From this behavior, it is requred to being assigned credits, but these documents does not refer to credits in this situation.
ArcGIS Online > Credits by capability
https://doc.arcgis.com/en/arcgis-online/administer/credits.htm#ESRI_SECTION1_709121D2C7694DCAB9B8592...
* I know that data  strage consumes credits day by day, but I would like to know credits just publising a scene layer from slpk...
I tested the same flow in ArcGIS Pro, but the result is the same as in ArcGIS Online and these documents of Pro do not refer to credits, too,
Share a scene layer package
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/scene-layer-package.htm
Share Package (Data Management)
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/share-package.htm
Credit allocation is required when making a tile cache in ArcGIS Online, so it may the same as when publishing a scene layer from a slpk.
"For example, with tile layers hosted on ArcGIS Online, there is no option to set the minimum and maximum number of instances of the service, because Esri handles the service scaling for you."
https://doc.arcgis.com/en/arcgis-online/manage-data/publish-tiles.htm#:~:text=For%20example%2C%20wit....
RussRoberts
Esri Notable Contributor
You will have credits required for the hosting of the 3D layer and the package which falls into 1.2 credits per 1 GB stored per month, calculated hourly.
RussRoberts
hitsujir_dev
Thank you for your comment!
Yes, 3D layer and slpk consume credits 1.2 credits per 1 GB stored per month as "data storages".
Other items are able to been published with non-credits-allocated users, so I'm curious this behavior that only credits-allocated users are able to publish 3D layer from slpk...
I checked credits cunsumption, but it seems to me that credits were not consumed just when publishing slpk.I wonder if a little bit credits are consumed just when publishng 3d layer from slpk.
3D scene layers and slpks are not reffed in detail in ArcGIS Online resources, so they are annoying me.
Regards,
Rina
MCh
May I ask more question?
When I add .slpk into ArcGIS Online, they create two item : Scene Layer and Scene Layer Package (the storage one)
I understand that 1.2 credits per 1 GB stored per month BUT it's used for storage file not the Scene Layer service that was built right?
So how could I know that how many credit consumed for the Scene Layer?
