How do you change to a custom basemap?
3335
04-27-2015 09:41 AM
JoshWhite
Honored Contributor
Is there a way to change the basemap to one different than the default ones?  I was interested in creating a web app for my cemetery.  Trouble is the default basemaps won't let you zoom in beyone 1:1128 (or may 1:564).  My application needs to go down to about 1:50.  The basemap isn't exactly important at that scale but I did create a basemap for the app for my FlexViewer and it works fine.  I would love to explore the Web AppBuilder functionality in order to move to a mobile friendly web application.
Josh White, AICP
Principal Planner
City of Arkansas City
JakeSkinner
Esri Esteemed Contributor
Hi Josh,
There are a few ways in which you can do this:
Customize Your Basemap in ArcGIS Online | ArcWatch
You can also configure the basemap gallery to your own basemaps that you've added to a Group within ArcGIS Online:
Configure map viewer—ArcGIS Online Help | ArcGIS
Also, here is a helpful document on how you can create a Tiled Service in ArcGIS Online.
JakeSkinner
Hi Josh,
VenusScott
I have a map that start with the ESRI topo basemap at the street scale so the user can get oriented. I then added our own aerial photography that won't display until a certain scale so when they need to do a precise point location they can. You can configure it in AGOL using the "Set Visibility Range" option on the map service.
http://phoenix.maps.arcgis.com/apps/OnePane/basicviewer/index.html?appid=f475dbc856a5479d8b677624f05...
