How do you adjust the map extent for a published map using  an IOS device?
973
07-19-2011 02:52 PM
AlanHamrick
I created a map using a CSV file for a mobile application. My problem is when I zoom in using the GPS location button on the application, the map extent is too small. I need to make my map extent larger when I use the locate button. Is there anyway I can adjust this? I can do it manually on the screen, but that is inconvenient when mobile.
